climate control fix
However, if you believe that your auto control is no longer functional (e.g. because the red lamps are no longer showing), the auto control feature along with the indicating lamps can be disabled when a specific sequence of buttons are pushed on the climate control head (e.g. often done with eyes on the road and not on the control head). Likewise, auto control can be turned back on, by executing a specific button sequence.
Likewise, your weather stripping question is vague as well. My guess is that you mean the vertical seal between the rear edge of the front window and front edge of the rear window and not the seals where the rear window rolls down into the rear quarter panel or up into the roof.
If both or either of my guesses are correct, you'll find the needed information/details by using the forum's search function.
