Help!
Old Mar 26, 2002 | 06:08 PM
Gizmo's Avatar
2000 CLK430 White/ Charcoal
Question Help!
I want to put a K and N air filter in my CLK 430 but I cant get the damn cover off the engine. is there a special way or tool to use to take it off? Also, why does the 1st gear when in tiptronic mode feel more torquey than when I leave the tranny in Standard mode?
00' CLK 430
Glacier white/Charcoal
Old Mar 26, 2002 | 06:09 PM
Mach430's Avatar
Yank it! The cover has little clips that keep it on. It just requires a little force.
Old Mar 26, 2002 | 06:22 PM
Angel_Dust's Avatar
CLK 430
once i yank the cover off....how would i proceed to put it back on?....are there special places where i should look for to clip the cover on again?
i just want to take the cover off to see how dirty my air filters are....
thanks in advance mach430
Old Mar 26, 2002 | 07:24 PM
RJC's Avatar
RJC
Various
[QUOTE]Originally posted by Angel_Dust
[B]once i yank the cover off....how would i proceed to put it back on?....are there special places where i should look for to clip the cover on again?
Yes little rubber gromets that the clips attatch to, Be careful after you've removed the cover to check the air inlet ( elbow shaped round black plastic screened peice that the back of the cover fits onto) is still secured in place as they can and do move a bit while removing the cover. I believe you may need a special tool to open the inside of the cover once it's removed to check the filter but I may not be recalling this correctly
