Eibach Springs
Old Feb 19, 2004 | 05:41 PM
fstrd1's Avatar
Eibach Springs
Hi all, I recently had some eibach pro kit springs installed on my clk and the rear actually is higher now by almost an inch than the stock springs. I know it takes at least a week for the car to settle on the new springs but I was wondering if this ever happened to anyone else who has used the eibach pro kit.
Thanks in advance for all the comments!
Old Feb 21, 2004 | 12:41 PM
clkal's Avatar
01' CLK55
Re: Eibach Springs
have you changed out the spring pads? the pads make a 1/4" difference every increment.
Old Feb 21, 2004 | 02:23 PM
Josh K's Avatar
Tesla Model S
I have the pro-kit and didn't have this problem. Wait a week I suppose and if it's still the same complain. Keep us updated. :0)
Old Feb 21, 2004 | 06:43 PM
fstrd1's Avatar
Re: Re: Eibach Springs
I never thought about that, I will check with the shop I use on Monday, thanks Ckal!
Old Feb 21, 2004 | 06:45 PM
fstrd1's Avatar
I am bringing it back into the shop on Monday which is about a week, I am going to follow up on ckal's advise about the pads, will update, thanks for the input Josh!
Old Feb 22, 2004 | 01:18 PM
Mach430's Avatar
Even without the springs settling to normal specs, the car should not be higher. My guess is you have a CLK CAB kit on your CLK Coupe. The CAB kits are designed for another couple hundred pounds in the rear, which you would not have, thus making your rear higher.
Thanks,
Ben
Old Feb 22, 2004 | 02:43 PM
fstrd1's Avatar
Thanks Ben for the info, can this cabi kit be removed? And if so will it effect the ride in a negative way?
Glen
Old Feb 22, 2004 | 03:12 PM
Josh K's Avatar
Tesla Model S
Wow, good looking out Ben, I didn't even think about that. If that's the case, then yeah the kit can be removed, and they have to replace it with the right kit. You shouldn't have to pay anything since it was their mistake.
Old Feb 22, 2004 | 05:35 PM
Mach430's Avatar
Glen,
What I'm thinking is that they installed springs that were meant for the CLK cab instead of the coupe. If this is the case, then they will need to order the correct springs and install those in place of what you have now.
Old Feb 22, 2004 | 05:41 PM
redcoupe's Avatar
11 ML350
Or they put the front springs in back and the rear springs up front.
Becasue the front springs are bigger, which would casue the rear of the car to sit up higher than stock.
Brian
Old Feb 22, 2004 | 05:57 PM
fstrd1's Avatar
Originally posted by Mach430
Glen,
Thanks Ben now I understand what you meant, I will contact the dealer where I bought the springs from .....did not even croos my mind to think of that
Glen
Old Feb 22, 2004 | 05:59 PM
fstrd1's Avatar
Glen
I mean CROSS my mind, this spring situation must really be getting to me
Old Feb 22, 2004 | 06:02 PM
fstrd1's Avatar
Brian
I am pretty sure the mechanic did not install the springs incorrectly...but who knows it does not hurt to check.
Glen
Old Feb 22, 2004 | 06:48 PM
fstrd1's Avatar
Hey Ckal how much are the spring pads and if it turns out that the springs are for the coupe and the springs are installed correctly what size pad should you suggest that I use for the rear? Right now I have 17s with a staggered set up of 225/45/17 in the front and 245/40/17 tires in the rear so I am not in danger of any rubbing but I may change out my wheels to 18s
Glen
