Fuel breather pipe for W208
The outside diameter is around 14,5mm which would need a hose with 14mm of inner diameter.
As known, there is a chronic issue regarding the two houses identified as A2024761827 and A2024768726. The hoses become brittle and perish. Whenever the fuel reservoir is filled, gasoline saps out and spills on the rear right arm and the floor. Quite a lot.
There are videos on YouTube to identify the specific place however information is lacking about their size. Thus, I want to share it with anyone who still hasn't changed them.
Difficulty level: Beginner
Tools: Needle-nose Pliers, Clamp cutter, specific rubber hoses.
A2024761827
- This tube has two different sizes.
- From the canister side it has an external diameter of 24.24mm and internal diameter of 17.63mm
- From the metal pipe side it has an external diameter of 21.79mm and internal diameter of 14.15mm
- Wall thickness: 3.5mm
- This tube can be sourced from any store as long as it's a proper fuel rubber hose. Mercedes couldn't source it.
- External diameter of 21.42mm and internal diameter of 14.32mm
- Wall thickness: 4.15mm (generic)
