Installing double din Pioneer, harness#?
2002 W208 CLK 430 Coupe
I read several threads and it seems most people take their cars to someone to install their radios so no one knew the harness needed to install straight to the factory harness. Does anyone know the part number and brand of harness adapter and antenna adapted to install my DD radio? It's the Pioneer AVH3700BHS. I do plan to eventually get the PAC boxes for the steering wheel controls and install a reverse camera. I also presume that I can use a pushbutton switch to imitate the parking brake activation for DVD function?
2002 CLK 55 AMG cabriolet Eurocharged
If you do not find what you are after at www.crutchfield.com then investigate www.newegg.com for alternatives.
Note Crutchfield has a lot of schematic information but lacks some of the later model Benz.
Cheers, Gator
Cheers, Gator
Cheers, Gator
Cheers, Gator
You need a module to integrate with the factory Bose amp. I think also a standard adapter type harness just to tap power if you want to. Here are the wiring diagrams and info:
http://www.fitzhughmedia.com/MBF/headunit2.html
For double-din, youll need the Pioneer sleeve kit, or some radios still come with the metal sleeve.
