2002 clk430 cruise control ?
https://mbworld.org/forums/clk-class...e-control.html
Process of elimination:
Cruise only works from 30mph and above.
So the wheel sizes are good, is the tyre tread wear from front to back fairly consistent?
Is there any warning signs on the dash eg, ABS / ETS / EPS? If so than this could be due to a faulty break switch (Very Common) and will inturn shut down the cruise.
Is the ABS working? (jump on the brake in gravel to try)
