P0170 and P0173 question
Old Mar 21, 2016 | 05:37 PM
HarleyW72's Avatar
2000 CLK 320 coupe AMG Edition
Hello folks, I am getting these codes for fuel trim on my 2000 clk 320 coupe but the car isn't missing a beat, no loss of power, no hesitation, no rough idle, no stalling. I do smell its burning rich but there are no performance issues. Any ideas? The MAF seems to be working or I would think it would be running like crap as most have in the past. Thanks
Old Mar 22, 2016 | 10:14 AM
jonUF02's Avatar
2015 GL550 4matic
http://www.obd-codes.com/p0173
Causes
Potential causes include a vacuum leak, unmetered air leaks Fuel saturated engine oil Leak in turbo air charge hoses (if equipped) Possibly bad O2 sensor (If Mercedes, may require adaptation with M-Benz compatible scan tool.) Oil contamination in MAF connector or O2 sensor connectors. Also check ignition coils, cam and crank sensors, and oil sensor for leakage contributing to oil intrusion in wiring harness. Defective MAF (Mass Air Flow) sensor (especially on Mercedez-Benz and other European autos. There are a lot of problems with aftermarket MAF sensors.) Defective fuel pressure regulator Leaking camshaft adjuster solenoids (Mercedes-Benz).
NOTE: for some Mercedes-Benz models there is a service recall for a crankcase vent hose located under the intake manifold. It should be checked for leaks/cracking and also operation of check valve in the hose. The check valve should flow only one way.
Possible Solutions
It should be stated right off the bat that the most common problem associated with this code is the MAF sensor or air mass meter. This is especially the case with Mercedes-Benz and Volkswagen and other European cars.
Old Apr 6, 2016 | 06:31 PM
HarleyW72's Avatar
Yep, was MAF intermittent issues. I replaced it and even the P0400 EGR code hasn't been back. Thanks
