W208 320 Crank, no start, sensors OK, fuel OK
Old Jul 2, 2016 | 06:50 AM
Grud's Avatar
CLK W208 320 1999
Hi!
I have hard problem with my CLK 320 Gasoline and LPG
Engine crank, start for 0,5sec and stop on gasoline, on LPG start and work.
I done bellow check list, please i need your help, cuz fight with problem since 2 months. All looks well but engine can't start //
1. camshaft position sensor - OK
2. shaft position sensor - OK
3. coolant temp. sensor - OK
4. fuel pressure - OK ~4,5bar
5. new fuel and air filter
6. new spark plugs and OK
7. all fuses - OK
8. electrical mass - clear, contact spray OK
9. Immobilizer - OK all 3 keys works
10. timing chain no backlash
11. ECU and K40 looks fine, like new without any smoke or dirt
12. car start on LPG
13. shifter isn't block
I will be grateful for any suggestions.
Old Oct 7, 2016 | 02:32 AM
beanie's Avatar
mercedes clk230 kompressor sport (w208)
fuel
Originally Posted by Grud
Hi!
7. all fuses - OK
Hi if it runs on gas then the problem will be that the fuel is not getting to the cylinders,you will have to check that fuel is getting to the injectors,maybe its not switching over to the fuel from the gas,food for thought,all the best.
