w208 headliner rear window trim
Old Jul 5, 2016 | 10:00 PM
bmorris0703's Avatar
02 mercedes clk 320 convertible
I have an 02 clk 320 convertible, that the headliner trim around the rear window, falls down, when the top is put up. Is there any way to fix, without having to buy a new liner? The tabs, that hold it in, are falling off. Thanks
Old Jul 6, 2016 | 01:56 PM
Serndipity's Avatar
2001 CLK320 Cabrio
The plastic surround used on the cabriolet rear window has had a tenancy to disintegrate over time and has been discussed numerous times.
Suggest you use the forum search to find prior threads on the subject.
While you'll find some that some of the threads to be dead ends, indicating that replacement part is not available, other threads identify the part number, its available at a reasonable cost, as well as how to make the repair.
