Lowering with spring only
Old Mar 26, 2004 | 04:41 AM
twboy's Avatar
i want to lower my car by changing the springs to H&R Sports springs
I seen some posts where ppl mention about spring pads, would the springs say what pads I need?
I also remember seeing post where ppl is having problem with their car because they changed their springs only and not the shocks?
any help is appreciated
Old Mar 26, 2004 | 07:52 AM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
H&R springs will lower your car 1.5" all around, if that is what you wan't you don't need to change the spring pads. Each pad will lower/increase your car height by 8mm, so you can play with them accordingly. If you like the ride with the standard shocks, you can leave them, only they will wear out quicker due to the fact that they are compressed all the time.
Hope this helps.
Old Mar 26, 2004 | 01:12 PM
hinhin7's Avatar
MB
Re: Lowering with spring only
Yepp, just like theine said, you would wear out your shocks faster than it was supposed to last. Check the classified, I think there is a set of Koni shocks being sold by a forum member here.
You could go for spring pads #1, it will give you a lower ride than if you go with higher # spring pads.
