W208 CLK430 Front End higher then rear???
Old Apr 2, 2004 | 07:44 PM
kimber45's Avatar
2001 CLK-430 Black
Is it normal for the front end to have more clearance between the fender and tire? My rear end looks perfect and the front looks as if I have a couple of hundred pounds of sand in the trunk. THe front is about 2-3 inches higher it seems.
Stock springs and 18k my01
Thanks in advance
RK
Old Apr 2, 2004 | 08:17 PM
Brian_I.'s Avatar
w211 & w124
I've noticed that too. I think it's just how it is.
Old Apr 2, 2004 | 09:06 PM
CiLKY's Avatar
13 S550 4Matic
Simple answer........front tires turn..........rears don't.
Basically the front needs more room because of the front tires turning and hitting bumps.
Make sense???
Old Apr 3, 2004 | 07:16 PM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
You can always use shims to adjust the height to your taste.
