Kleeman Pulley...what is it?
clk 430 Black Coupe
I've read a reference to a Kleeman Pulley upgrade in a couple of the posts...what is it....how much does it cost, who installs it and what gains are realized. Thanks, I have a 2000 430 coupe.
2017 C63 | 2018 E63
The pulley kit is for the M111 Mercedes 4 cylinder engines (230K models) equipped with a factory kompressor. The kit replaces the factory kompressor pulley to create more boost pressure and thus more HP/Torque.
Here's a better idea of what the Kleemann Pulley kit can do to a factory supercharged engine:
To find out more, feel free to contact any authorized Kleemann dealer, such as myself, or visit Kleemann USA to view a list of Kleemann dealers.
pulleys
It's an old racer's trick. Don't get me wrong, it works. You are just changing the ratio of the wheels which might mean a differrent belt (though usually there is adjustment in the belt bracket). The Pontiac GTP / Ford Lightning guys go for the pully swap a lot - just spins the blower faster = more boost = more hp!
Same thing goes for your accessories (power steering, altenator, waterpump, etc). "Underdrive Pulleys" spin your accessories slower reducing parasitic hp loss on the crank. You just have to be sure that everyhting still runs within the needed tolerances or you could have a dead battery, or a water pump that cavitates. I have had them on my Nissan for years- http://www.se-r.net/engine/unorthodo...eys/index.html
or check out...
http://www.unorthodoxracing.com/
I know EvoSport has them for BMWs (as I read in European car - way to go Simon!)
~shell
clk55 - 13.7 @ 107
or check out...
~shell
clk55 - 13.7 @ 107
