CLK soft top won't open but close ok
Old Aug 5, 2017 | 03:26 PM
SuperKaribou's Avatar
CLK Cab W208
CLK
Hi,
Old Aug 12, 2017 | 02:03 PM
captncrunch's Avatar
2002 clk320
top closes but won't open
I recently acquired a 2002 clk320. The dealer salesman opened and closed the top twice using the correct procedure as shown in the owners manual. When I got it home I found that I have to physically push the top up past the first hinge to allow it to move. The hydralic motor is running but the top just won't quite go up by itself without a little help. When I close the top everything works fine but the top slams down on the windshield. Any ideas from anyone?
Old Aug 13, 2017 | 08:47 AM
Serndipity's Avatar
2001 CLK320 Cabrio
Your roof's tension cables are broken.
You can buy a new pair for around $200, which can be DIY installed.
Old Sep 23, 2017 | 09:43 PM
Daryl Little's Avatar
2002 clk430 cabriolet
Soft top won't open
The soft top on these cars need to be unlocked then manually lifted aprox 12 inches before it will retract into the trunk
Old Sep 24, 2017 | 01:25 PM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
I agree it is the tension cables, the slamming down of the top is a major clue. When you unlock the top you need to push up and the cables should hold the top in place (about 6") and then you should pull the top lever glowing red to complete the opening process. Close process is reversed and the tension cables stop the top from slamming on the windshield.
Old Sep 24, 2017 | 01:56 PM
knowbenz's Avatar
Benz
Originally Posted by SuperKaribou
Hi,
So you made this post, then somebody else posted details about their top problem and got several responses that make sense.
