CLK(A208) convertible, headset(roll Bar)problem
Old Nov 10, 2017 | 03:44 AM
corrado90's Avatar
Mercedes CLK 430 Cabrio
Why my rear headset(Roll Bar) is automatically rising up when open soft top?
Is there any simple way to fix? Thanks.
Old Nov 11, 2017 | 12:39 PM
Serndipity's Avatar
2001 CLK320 Cabrio
When opening the power roof, if the roll bar was previously in the up position, it will automatically lower. This is by design, in order to provide the necessary clearances, during the power roof operation.
As you mentioned in yet another post, your trunk may not open, which is also by design. If inputs to the power roof controller, indicate that the power roof is not operating normally, to prevent a collision between an open trunk and soft top compartment cover, the central locking system will not allow the trunk to open.
As far as a simple fix, first carefully read and try the 'subsequent locking procedure' which is described above.
However, it appears that your issue is being caused by a malfunctioning roll bar, which likely will need further diagnosis, troubleshooting and repair. If so, the forum already has numerous threads that will help you resolve the problem.
Old Jan 31, 2018 | 09:01 AM
iamtngg's Avatar
w208 clk320 convertible designo
Hello, my rollbar control button don't works, when i push it, it operates passenger door glass. (headrest stays in upper position and i think that's why my soft top stopped working)
+ the glass button does nothing at all. any ideas ? or which module controls this operations ? thanks
