Losing power on acceleration
Old Nov 14, 2017 | 10:38 AM
Neegerii's Avatar
CLK 230K -99
Hello, I have clk 230K -99
So the problem is that when accelerating it loses power trough some rpm and then gets the power back and loses again. So basicly the power output is swinging when accelerating.
My own quess is that the MAF is broken or going to brake, because i have cleaned it couple times earlier and that has solved the power output problem, when i had basically zero power and it started to run on 3 cylinders.
I havent had this power swinging problem earlier, and cleaning the MAF didnt help, so is it broke?
Old Dec 28, 2022 | 01:24 PM
CLS55_Ian's Avatar
CLS55
If you want to rule out the intercooler pump, just perform the cooling system bleed procedure using the inctercooler pump...
Connect a 5/16" hose to the bleed valve, clamp the supercharger line below the bleed valve, and put the other end of the 5/16" hose in the overflow reservoir. Then you go in the trunk and remove the bottom-right relay and short the two vertical slots; this will apply power to the intercooler pump. If you see coolant flowing through the 5/16" hose, then your intercooler pump is not the issue.
Sorry, I know I probably didn't explain that process very well.
