Key FOB Not Functioning Correctly/Weird
Old Nov 20, 2017 | 11:23 PM
jorj_818's Avatar
2000 Mercedes-Benz CLK 320
Hello, I have a 2000 CLK320. When I purchased the car the Key Fob batteries were dead so I switched them out today and when I press on the buttons ounce the red light does not flash. I have to press on it pretty hard for like 5 seconds(max) for the red light to flash and the task to work. When I press locks it locks the doors but when I press the unlock it doesn’t unlock. The trunk opens but again I have to press pretty hard and for 5 seconds. When I lock the doors with the remote I can’t open it so I have to use the key and when I do that and open the door the alarm goes off until I put the key in the ignition. Please help I do not know what to do I’m new to Benz this is my first car and first Benz. All help will be appreciated . Thanks!!
Old Nov 26, 2017 | 08:17 AM
cindyclk's Avatar
first I would try another set of batteries
Old Nov 28, 2017 | 11:47 PM
Aussiesuede's Avatar
SL500
Unplug your battery for 5 minutes and then reconnect and see if that helps.
Old Nov 29, 2017 | 12:21 AM
cindyclk's Avatar
...after new batteries...disconnecting will force you to resyc all your settings...seats, windows abs, sunroof etc...try simple first
Old Nov 29, 2017 | 09:22 PM
MacVidMB-V8's Avatar
W209, W124
If you only;y have 1, go (quickly) to MB dealer and order a 2nd key while you can easily drive there.
After you have perfect, new key, then worry about fixing older one.
