Soft top stops part way up.
A breakout box was required back some time ago to access the top controller on this car. STAR is known for diagnostics and Xentry repair. SDS is new for me but I have been out of the loop other than CAN protocol development.
Thanks for the explanation. Most repairs are hopefully helpful to shade tree DIY in the forum.
Regards, Gator
Next, I couldn't agree more, with your above opening sentence, that the forum has previously posted a treasure chest of information. Specifically, numerous times, I posted a functional diagram of the power roof controller, but more importantly, also detailing the inputs/outputs required at every stage of roof operation etc., which is the key to successful troubleshooting and repair (e.g. the controller connector pin-out, how to test/troubleshoot at every stage of power roof operation etc. .
Note: All of the controller inputs (except those from the CANBus) can all be verified, by disconnecting the controller connection and takings resistance measurements with a multimeter. Only checking the controller outputs, requires the MB break out box, mentioned by GatorMB, which would point to a faulty controller/pump solenoid valve etc.
All this said, I am still an original owner of 2001 cabriolet, while yet, no problems with my power roof operation, which I have a theory as to why.
That said, the W208 has proven to be one of the most reliable MB vehicles has recently produced. However, the cabriolet design is a looker/keeper and will wind up in your shop, for time forward.
Important, MB did some significant upgrades to the power roof system, on or about 2001. Specifically,in later production, the pump assembly, only uses 5 solenoid valves (e.g. vs. 7), some of the position position/limit switches were eliminated (e.g. involving the soft top cover), which then involves very different controller and programming. Note: From what I can see from the updated WIS electrical schematics, the connections at the controller, still remain the same (e.g. just the controller software programing has changed).
