Instrument Cluster Vertical Lines
If it's only the temperature and/or /clock displays, which has been a very common W208 issue( e.g. displays random and/or missing digits), it's correctable at low cost via DIY or rebuild.
If it's the center display, as both an long time forum member and original owner......the ribbon cable in this case, is more more secure/fastened and I've yet to read about any issues with it.
However, given the vertical lines, it seems that either the main cluster display component, it's controller chip and/or the inter-connections, began failing intermittently and have since totally/finally failed.
Hopefully, before spending $$$$$ at a dealership, for a new/coded cluster, if you're familiar with electrical cleaning/re-soldering electronic connection techniques, your repair may be $0.
As mentioned in my prior post, the W208 cluster has 3 display panels, as shown beginning at 1:40, in the below cluster repair video.
This video explains how to DIY replace the faulty ribbon cables, which you can purchase for around $5.
Alternatively, others on the forum have sent the cluster to BBA Reman https://us-shop.bba-reman.com/ for repair, with excellent feedback regarding their service. I believe, they charge around $150 to replace just the ribbon cables.
However, if the problem is a poor solder joint or faulty display unit, it will cost more.
