CLK w208 ABS/ESP, Won't shift into gear, seat stuck front & roll bars deployed.. HELP
1. I found a video showing how to remove the seat switch without removing the door panel so I am going to switch the switch for the passengers seat that I know is working and also disconnect and reconnect the seat motor wire harnesses.. If that doesn't work then I will look at accessing the fore/aft motor by removing the seat material. Anyone have pictures on how to do this? Yes I have switched out the fuses to no avail.
2. I have ordered a stop switch since it is cheap and they are known to fail to see if that has an effect on the transmission. I also turned wheel to left and right trick with no luck. .
3. Yesterday I was able to manually release the top, I tried different angles having the front of the top raised and couldn't get it over the roll bars, finally by being in the back seat I was able to move the top over the bars and put in the trunk, there is only a faint click for the roll bars when I press the switch.
4, My main goal now is to get the issue with the shifter and abs/esp fixed first. Could the ABS/ESP be causing this problem with the shifter?
5. I see no reason to fix the seat if the switch switch is not the problem and same goes with the roll bars since they are such a PITA unless I get the shift into gear issue resolved.
If you have input on any of the above numbers I welcome them, I don't want to give up and sell it as a fixer upper. Thanks in advance.
Make sure you get the updated genuine MB switch, for around $20 and avoid the cheaper knockoffs.
