Steering Wheel Not Controlling COMAND Head Unit
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Hello guys I lucked up on a full functional comand head unit from a junkyard for only $12. Hell of a deal I would say!!!
The problem I'm having I can't get my steering wheel to control the unit. The unit came out of a fully loaded facelift Eclass. I have it installed in a 02 clk
I've hooked up everything but the gps, cd charger and Vss wire. And im not sure if the vss has something do with it not working right or if it's my original radio harness that's not configure for a comand unit.
All I want from this comand unit is its
Good looks in dash
Steering wheel controls
Aux input
I don't care about the gps its out dated anyway
So my question are
1. How can I get the steering wheel to control my comand?
2. What's is the vss wire for and is it necessary ?
3. Is this something the dealer has to program or should this be plug and play?
Thanks for reading
Good looks in dash
Aux input
So my question are
Thanks for reading
You need to code your ECU with dealer's StarDiag or equivalent to recognize that the Navi is present - it will not auto recognize. The VSS wire is necessary to give feedback for your car's movement relative to the GPS position which will also not work if you don't have the GPS antenna hooked up to the unit. I'm pretty sure third party GPS antennas are available by this point.
