Bouncing Passenger Window
Old Apr 18, 2002 | 03:53 PM
Silversun430's Avatar
CLK430
Unhappy Bouncing Passenger Window
Anyone had the problem where the drivers side or passanger window bounces when putting it all the way up or down. I have taken it to the dealer twice and they say they can't find anything wrong. Any one have comments or opinions on this?
Old Apr 18, 2002 | 04:08 PM
Mach430's Avatar
What do you mean by bouncing? Are you referring to when the window closes and then reopens about 3" down?
Old Apr 18, 2002 | 04:15 PM
CLK430
Bouncing
It stutters. Like when I put the window all the way up. and then use the automatic let down so the windo goes all the way down, at about half way the window bounces or stutters or jerks and then goes down all the way.
Old Apr 18, 2002 | 06:26 PM
Bjorn's Avatar
CLK
I have had this problem before too. I think its due to the window not being clean. Not really sure but thats the only conclusion I can come up with.
Old Apr 18, 2002 | 09:00 PM
CLK 320's Avatar
2001 CLK 320
Windows
I have also found that if the windows are cleaned, inside and out, they are much smoother.
Old Apr 18, 2002 | 09:21 PM
LowRydeR's Avatar
I have this problem too, I'm going to have the dealer to fix it for me.
Old Apr 18, 2002 | 10:39 PM
renncpe's Avatar
w203 c230K 2002
Re: Bouncing Passenger Window
A bouncing widow simply means it bounces on the way up but still goes up. This can be corected by window cleanleness. I recommend applying a wax such as meguiars mirror glaze. If you get the window too clean however it will still grab the seals and bounce. I recommend using a lube after the window is clean such as a powdered graphite near the edges of the window (not in the viewing surface of the window). A complaint where the window goes back down ofter using the express up feature is different. An MB dealer should be able to recitify this situation. The problem was caused by DCM (door control modlue) issues. The DCM's were not reading the window position correctly. There are fixes for this problem that can be performed using the SDS at a Mercedes Dealer. I hope this can help you fix you problem.
Randy
Old Apr 24, 2002 | 06:14 PM
quaz's Avatar
CLK 430
Interestingly, my window did that exactly twice....after I purchased the vehicle.
I thought I was just doing something wrong....so I kept trying.
After about 4 tries...it worked properly....and i haven't had a problem since then.....this was 3 months ago.
quaz
Old May 1, 2002 | 11:49 AM
sungulent's Avatar
2002 mercedes clk coupe
i had the same problem on my clk the driver's side
took it to dealer they changed a whole brain unit my car was there for 4 days re this problem
after i took it back my windows worked all normal. however mechanics there messed up my electronic mirrors
i still have to take it back for mirrors i just dont want to leave the car for another week or so
sorry house of imports but your service department need some improvment
your sales department - they are the best
