can m113 exhaust manifolds be flipped upside down?
just brainstorming some ideas
Thanks!
I have two m113’s in my garage right now on engine stands, I can send photos if needed
yes the manifolds can be flipped around, but depending on your chassis, your engine accessories(abc pump takes up a lot more room than a standard steering pump for example), and engine bay layout, you will have to cut off the oem exhaust manifold outlet and redesign the exit angle. On almost all m113 setups, you’re going to hit things like the steering pump or alternator if you tried to use the stock manifolds as-is
