Confused TPS location
2005 clk 320
Good day mbworld. I’m a little confused on finding the exact location of the TPS(throttle positioning sensor) on a 2005 clk 320(w208). Is it around the master cylinder or behind the accelerator pedal? If you can send me a link illustrating the location, I would be much obliged.
Sincerely,
Nelson
Sincerely,
Nelson
2005 clk 320
Vin request
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
I think you need to tell us why you are looking for a TPS sensor that is not apart of your ME SFI 112.955 engine----you have a throttle body actuator and a pedal position sensor and a load of shist between!!!
2005 clk 320
TPS location dilemma
sincerely,
Nelson
2005 clk 320
Re:Diagnosis
Good day Plutoe. First off thanks again. I had gotten the vehicle Diagnosed but the only error codes I got was from the o2 sensors. Those will be changed. I already changed injectors, coils, spark plugs, and wires. Cleaned the MAF. Changed back to OEM air filters from the K&N I initially got. After doing this maintenance, I reset the computer. After going on a test run, there was a slight delay in the throttle response and the reason I’m looking for the stop lamp switch is because my dash displays an ESP error message. I got this CLK with basically no historical maintenance and that’s why I’m trying to slowly eliminate the error codes.
Sincerely,
Nelson
Sincerely,
Nelson
2005 clk 320
Problem solved!
Good day. After changing the MAF sensor, everything is running smoothly and no check engine light. Special thanks to Plutoe for assisting me.
thanks,
nelson
thanks,
nelson
