2002 Clk320 3.2 HELP
Old Jul 12, 2019 | 03:30 AM
320drifter's Avatar
Clk320 e320
I was driving my 02 clk320 around all day till around night time the car was running rough when I got to a complete stop and hit the gas the lights went dim and the rpm went lower then what they were and the engine popped like it back fired barley made it home with car having little power, also after it backfired the cel went off as it was on before for 02 sensors and misfires, the next morning I turn it on and it runs fine I drive it through the neighborhood and it turns off while making a u-turn and when I turn it back on it cranks and runs half a second with a wobbly idle and dies, I thought it was a vacuum leak and checked and made sure all hoses are connected so I towed it home tired it a couple hours later and it turns on and stay running with the cel still off.
Hoping to be able to fix as I love the car but thinking about sell before another expensive fix
260k miles oil changes done every 4K miles had the car since 220k never checked spark plugs could be factor? Any info is appreciated 👍
found out a spark plug wire popped out and had oil in
Old Jul 12, 2019 | 06:54 AM
speedlimit's Avatar
Administrator Emeritus
Hi!
Welcome to MBworld!
I'm moving your post to the CLK320 forum, thanks!
Bob
Old Jul 12, 2019 | 07:01 AM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Please post a photo of the CLK. Sounds like an electrical problem. Have you replaced the battery(ies)?
Old Jul 13, 2019 | 09:07 AM
320drifter's Avatar
Clk320 e320
Never changed the battery since owing the car I do have a 1500watt amp I put in when I bought it but never had any problems with it.
Attached Thumbnails 2002 Clk320 3.2 HELP-ef082dac-179c-4315-8def-524aa0cc91b0.jpeg
Old Jul 13, 2019 | 09:33 AM
chassis's Avatar
2017 GLE350 4MATIC
Thanks. What other modifications are on the vehicle?
Easy first step is to replace the main battery and auxiliary battery, if this vehicle has one. Then see how things behave.
Old Jul 13, 2019 | 10:05 AM
Serndipity's Avatar
2001 CLK320 Cabrio
Hoping to be able to fix as I love the car but thinking about sell before another expensive fix 260k miles oil changes done every 4K miles had the car since 220k never checked spark plugs could be factor? Any info is appreciated 👍
Sounds a lot like a failing crankshaft position sensor.
http://www.mercedesmedic.com/crank-s...sition-sensor/
https://www.fcpeuro.com/products/mer...sor-0031532828
