Help with Alternator DIY guide please!!
Thanks in advance for taking your time reading this post
While there can be other reasons for this, such as wiring connections, a common problem is that the graphite bushes in the voltage regulator wear down, such as they no longer make a connection to the alternators slip rings (see the videos below).
On your CLK430 it's probably going to necessary to remove the alternator to replace the regulator, but on the CLK320, I'm pretty sure the regulator can replaced from underneath (e.g. after just removing the splash plate), without removing the alternator.
During W208 production, MB used both Bosch and Valeo alternators, so you will need to determine which one your vehicle is equipped to purchase the correct part (e.g. using your VIN and checking the EPC (electronic parts catalog), dealership parts department or the label on the alternator.
https://www.youtube.com/watch?v=uQP8...KrhrT&index=15
https://www.youtube.com/watch?v=VnKZ...KrhrT&index=22
I was able to removed the alternator and here some pics on my voltage regulator, still confused, should just change the voltage regulator or should I buy a new alternator, please help me to
e
Ellioth......you have made a lot of great progress.
Your 1st picture, verifies that your vehicle had a Bosch alternator installed, showing both the OE MB and OEM Bosch part numbers.
As suspected, the next 2 pictures definitely show severely worn brushes and/or weak springs. Note that the brushes don't even make contact with the slip rings on the alternators rotating armature shaft.
The last picture shows the part number for alternator's voltage regulator, from which you'll be able to price and purchase a replacement voltage regulator vs a completely re-manufactured, which will also replace additional wear components (e.g. bearings, clutch pulleys, terminal hardware etc.).
Here is the Bosch part number (AL0766X) and typical price for a completely re-manufactured alternator. Note that there is a $100 core exchange and that you'll reuse the belt pulley from your current alternator.
https://www.fcpeuro.com/products/mer...-bosch-al0766x
You'll learn more regarding the specifics on the Bosch re-manufacturing process and benefits at:
https://www.boschautoparts.com/en/au...partID=AL0766X
