Sliding sun/moon roof won't close completely (because of the plastic wind "flap").
Like the title says, my sliding sun/moon roof won't close completely, because the plastic wind deflector "flap" isn't laying down low enough (like it's supposed to) when the roof is closing, so the glass catches on it. I can physically push the flap down and the roof closes just fine and I (otherwise) have full functionality (thanks to a new motor and dome/switch assembly).
The deflector/flap looks like it's fine on both sides. If you push the arm down on either side, it goes down like it's supposed to.
EDIT: After further inspection, I noticed that the glass has a tab underneath each side, which makes contact with the wind deflector rails when closing. That's what forces the wind deflector down. It seems that after 22 years of use, the tabs have simply worn down to the point where they can't push the arms down low enough for the deflector to clear the glass anymore (we're talking millimetres) - and since I found countless threads & posts on the internet where people have had this exact same problem, but for some reason never came up with an answer (that I could find) other than "take it to the dealer", or "try resetting it", etc. - I figure I might as well come up with a solution myself - and I did.
Find the tabs and (carefully) bend them back down as best you can. That's it. No spending money. No resetting anything. Just bend 'em (carefully).
Hopefully this helps the next person who needs it.
Cheers!
Cheers!
2MERKS
The tabs are attached to the glass roof (one on each side). They engage the rails on both sides and the rails lower the wind deflector. Age causes the tabs to lose their proper angle. Bending them down slightly (and carefully) solves this problem.
Enjoy!
