bolts stripped
Old Aug 15, 2004 | 01:38 PM
frappe's Avatar
02 CLK 430 blk/blk
bolts stripped
Most of my bolts are already stripped pretty bad....... anyone can suggests me where to get them and maybe their specification other than the dealership? Any input will be appriciated
Old Aug 15, 2004 | 02:20 PM
rajah996's Avatar
CLK55, CL500, Q45
which bolts?
Old Aug 16, 2004 | 09:53 AM
frappe's Avatar
02 CLK 430 blk/blk
Originally Posted by rajah996
which bolts?
The Bolts for wheels
Old Aug 16, 2004 | 06:06 PM
str8ridin's Avatar
05 E55
Bolts are stripped? Or lugs? Whover rotates your tires, have them do replace them for free since they stripped. Unless you did, , then I would take it to a regular tire shop and they can knock out your current bolts and replace them with new ones if that's the problem. If it's the lug nuts you're talking about, try NAPA or Autozone or online.
Old Aug 16, 2004 | 08:46 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Have you taken the wheels off your Mercedes before? There's no lug nuts or studs. There are only bolts (also called lugs)... lug NUTS are different from lugs, studs are different from bolts. Your Maxima has studs and lug nuts.
He should find out why they are stripped before buying new ones and having the same problem. Generally running a tap through the hub helps clean up the threads to avoid stripping problems in the future.
-s-
Old Aug 17, 2004 | 01:09 PM
str8ridin's Avatar
05 E55
oh, my bad..
