Squeak from HELL Ft dr side
I have sprayed every single piece of rubber replace the shock and sprayed in the spring area. I cannot find where the squeak is coming from it is definitely in that area when you take the tire off I crawled underneath the middle of the car thinking it might have been the steering damper or will the tie rod connects to other pieces it is not there.
The only one definite scenario is if you push the car up and down or if you turn the wheel all the way to the right and start steering back the opposite way and go back and forth. My thought is it can't be the shock because it happens when you turn the wheel left and right while it's on the ground it can't be the spring either so it has to be something to do with when the car bounces up and down and when the steering is turned left and right. Again my problem is I saturated all those bushings with PB blaster and still squeaks. Ball joints dry?
I am convinced it's the ball joint. The ball joints are easy to replace on these cars 20 min job
