EIS Removal
Old Mar 11, 2021 | 05:04 PM
2dogsrock's Avatar
2000 Mercedes CLK 320 Convertable
Question EIS Removal
I know I need to replace my EIS. I also realize it need to be programed to match my VIN. How do I remove it? I have the tool. If I remove the instrument cluster will I be looking down at it for easy removal or do I need to get to it from below?
Thanks in Advance!!
Old Mar 12, 2021 | 07:41 AM
Serndipity's Avatar
2001 CLK320 Cabrio
All you need is to do to remove the EIS, is to remove the outer ring collar from the module, by turning it anti-clockwise with the help of a small screwdriver in the ring's slot, upon which you'll be able to pull the EIS out, from the inside of the dashboard.
To pull the EIS out from the back of the dashboard, the quickest option would be to remove the bottom panel, located above the brake pedal, by just removing a couple of Phillips screws.
Old May 29, 2025 | 01:22 PM
Richard_Mutt's Avatar
Hi-
I did this but was not able to reach the EIS from underneath. Am I doing something wrong? I even removed the instruments to try and get its through there and had no luck either. Anyone have ideas?
Old Jun 1, 2025 | 05:00 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Old Jun 1, 2025 | 08:56 PM
Thank you. I feel like I did this but I will try again.
Old Jun 2, 2025 | 09:16 AM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
Learned what EIS is today. Electronic Ignition switch. Kind of learned how to remove it, but I really rather doubt that I will ever try it myself. Anyway, they say you learn something new every day. I got done early.
Old Jun 2, 2025 | 02:48 PM
MacVidMB-V8's Avatar
W209, W124
I'd love to get a look at a dead one. Curious if it is cold solder joints or bad caps that takes them out.
