clk cab trouble
Old Sep 7, 2004 | 06:36 PM
lacapo481's Avatar
clk cab trouble
hi guys im a new member with a 99 clk 320 cab
over the weekend mt top died when i try to engage it my windows go down but thats it it doesnt release from the trunk with all the experts out here any suggestions i cant get in the dealership for 2 weeks im thinking its the switch and praying its not the motor any help will be grateful thank you
Old Sep 7, 2004 | 07:43 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Make sure the plastic basket that the roof folds into is in the up position and seated properly (there is an inter-lock). Also if the truck is not closed securely, it has an inter-lock as well.
Old Sep 9, 2004 | 03:47 PM
benzinoben's Avatar
99 CLK 320, 2000 GSXR 750
Check to see if the switch you use to raise and lower your top is blinking. If it is, then it is probably the basket in the trunk isnt properly latched. This also happens if you have your trunk unlatched. The blinking light on your switch will tell you the car is doing what it is supposed to and that you have something not latched properly. Put the top back up and go through everything again, basket, trunk, etc....then try again.
