Typical CLK-320 Running Temp?
Old May 13, 2002 | 06:20 AM
jnjrowland's Avatar
I have an '02 CLK-320 cab and it appears to run about 10 degrees hotter than my '00 E-320. Basically on the E the temp needle sits mid to upper portion of the "8" (in the 80 mark on the temp gauge), while the CLK often runs with the temp at the high point of the "8" to slightly just above the "8". I wonder if this simply an acceptable tolerance in the differences of the vehicles or do I need to have this looked at by the dealer?
If anyone else could let me know what their CLK's run at re: the temperature range it would be appreciated.
Thanks,
John R.
Old May 13, 2002 | 07:31 AM
CLK 320's Avatar
2001 CLK 320
Temp
John, my CLK's temp runs in the same range as yours.
Old May 13, 2002 | 08:00 AM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
same here... so no worries my friend!
Old May 13, 2002 | 09:49 AM
jnjrowland's Avatar
Thank You
Nice to hear from you folks. Just odd that the same engine runs in two slightly different ranges. Perhaps due to the underhood packaging and being tighter in the CLK vs. the E? Anyway, thanks again, you have to love the boards for the information from knowledgable folks....
JR
Old May 13, 2002 | 03:46 PM
Newbie's Avatar
My 430's temp needle is always above the "halfway" mark. Pretty normal.
Old May 13, 2002 | 04:49 PM
karl k's Avatar
2002 CLK 55 AMG Coupe ;)
Same here: low 80s C to low 90s C.
Lucky us MB buffs.
My 2001 vette ran up to 230F = normal.
However, with 100 F outside temps in S. Florida, my eyes were glued on the
analog & digital temp gauges, - always!
Thank god, heat is not an issue with the AMG
Old Mar 15, 2023 | 07:31 AM
Tonestar70's Avatar
2000 CLK320 Cab
20 years later!
More than 20 years later and I just jumped on here to ask exactly the same question. Thanks for the info and the peace of mind!
