Trunk Lid will not open electrically
I cannot open then trunk using the mechanical key (I’ve used wd40, lubricant etc) as the cylinder does not rotate in any direction.
i can open and close the windows using the key fob only.
my assessment is that it’s ECU thinks the car is breached in security.
any help on how to get to trunk?
1. Check fuses under the bonnet/hood.
2. Try starting the car and then trying the switches. Your battery may not be able to hold enough charge for things to work properly.
3 If you have a coupe you can get in through the back seat.
4. Try this to "Jump start" the boot lock >>>
6 Very worst case - you have to cut your way in >>>>
GOOD LUCK.
PS. Good second hand convertible boot locks with working keys go for about £200 and are like hens teeth to get hold of. A coupe lock will not work on the soft top. I spent years looking for a good lock and was lucky to buy a boot lid with a working lock about 2 years ago.
