Oil Pressure Gauge wiring and Scuttle Jobs
I pushed the single wire through with hardly any resistance and you'll need to remove the under dash panel to access the wire just above the carpet (sorry about the dark photo). Whilst doing this job I did a fair bit of cleaning and found the scuttle tray main drain (blue arrow) to be fully blocked with leaves and debris. Used a flexible piece of plastic and water to clear. Also replaced the perished sealing foam on the fresh air damper, see photo. Hope this is useful for someone.
