Need Engine swap info CLK320/C43 V8
HELP ! I need to know if the stock transmission in my 02 CLK320 will work with a 99 C43 AMG V8 or how to modify it to work with this engine, I also need ANY swap info necessary to make this work. My V6 was dead on purchase and I found this 4.3 V8 very reasonable with ALL the goodies including computer. Will this engine even bolt up to the trans I have ? Benz and Hollanders say I have a 722618 ? or a type 607 , the 430 cars run a different transmission but I am not sure if it is an internal/electronic difference or a PHYSICAL difference. ANY ? ALL help , advice , info, links ,etc welcome, and I need info QUICK !!! Also concerned with radiator size and catalytic converters being possibly different.
Wow...hope you're extremely mechanically/technically knowledgable. As difficult of a task it is just to fit the engine, you are going to have to trick all the ecm's to work with eachother and recognize eachother. Good Luck!!
well......
The fit is not the problem...I measured everything and the engine WILL bolt in in place of the V6, same spacing on the mounts, puts the bellhousing in the proper placement, etc. My local dealer "SAID" they could reprogram the car to the ECM that comes with the engine, its the TRANSMISSION nobody seems to know about. Physical problems are not the issue, like you said, compatability of electronics and if the bellhousings match is the issue I am having trouble with, check out ebay auction #7922564401, thats the engine I am considering...does ANYBODY know a swap meister out there that MIGHT have some first hand knowledge ?????????
HEEEELLLLPPPPP !!!!!
The crackshaft on the 430 engine is stronger than in the 320 engine and this force must push down all the way to the wheels.
The ECU is not going to run the 430 engine either. So you will need a new one of those units too.
You can forget about quick info, you will need to do months / weeks of research before you even consider what is possible. So far you have done just visual but you need full break down of parts and fittings. You need a copy of Compact EPC from one of the eBay sellers.
