My son just got a 2011 E350 and I was so impressed with MB engineering and build that I went out and got my wife a 2003 CLK 430! It only has 45,643 miles on it and is in great shape!
Yes there are a few small things that need attention, but I learned a lot about a bit of everything pre-purchase here on MBWorld! You guys are great and knowledgeable! Can't wait to join the discussions!
To the tire questions - I have never had staggered rims or super hi-performance tires before, I have only had the standard 4-5 rib highway tread pattern. The current rear tires on the car are Michelin pilot 245/40/17 Z rated, as I understand it that is a standard OEM type tire. They have plenty of tread, but they REALLY sing at highway speeds, regardless of road type and I would like to get some suggestions on suitable replacements in the near future. We will not be hot-rodding or driving aggressively.
1. - What is the quietest tire for this car? Does that fat outboard tread cause road noise? Is it necessary for handling, safety and stability?
2. - I am all about MB recommended specs, however, can you move up in tire aspect ratio (from the 245/40's to either the 245/45 or 245/50 ) to get a taller sidewall for increased comfort without causing safety or monitoring issues, or causing a fender rub situation? and do they have to be Z rated or can you come down to a Q,S, or R?
Everybody loves pics so here are a couple -
The new baby - and yes those are clear original headlights!
Looking for QUIET tires. These have that wide outboard tread pattern.
Q1. I run 225 40 18 on a 18x8.5 et35 Front and 255 35 18 on 18x9.5 et35 rear.
Q2. Michelin p sports rubbers are good , and the yokos' too. I had Goodyear lowpros, and took them back about 2 weeks later.
Those are MY faves, but check out tirerack info on tires, and interweb. Nice find on your 430.
GL
R,
2Merks
GL
R,
2Merks
Any of them particularly quieter than the others? Why did you take the Goodyears back?
My wife was driving on Hi-way and rear tire blew.. Only had new tires installed for about 1 week. I returned and then purchased pilot sports.
R,
2Merks
