1999 CLK 430 doors will not open from outside
Old Dec 2, 2022 | 06:28 AM
CBonis's Avatar
CLK430 1999
Question 1999 CLK 430 doors will not open from outside
I am hoping for help to solve a new problem with my 1999 Mercedes CLK 430 coupe. The driver door was not closing and I had the door lock actuator (with door lock assembly) replaced. I do not know if related to this or not but a few days later, both doors stopped opening from the outside. the locks "work" meaning that I can use they fob and the locks raise/lower, but the doors will not open. To enter the vehicle, I need to use the mechanical key to roll down the windows and open the door from the inside. I find it hard to believe that something mechanical on both doors failed at the same time but hoping there might be an easy fix that I can implement. The car is of sentimental value to me but it is becoming quite the money pit and hoping I can figure out the fix on my own. Thanks for any help!
Old Dec 4, 2022 | 09:12 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
....May i suggest viewing vides from Youtube. The benz vides are pretty much all the same so it really may not matter which type to view C CLK SL of the year. Good luck
R,
2Merks
