Instrument panel left and right LCD's link
Old Jun 12, 2023 | 09:03 AM
marko69's Avatar
'01 CLK 430 cab, '04 SL500 (230K miles)
Just wanted to post a link to the bottom left and right LCD's, I just did this job and I can verify that these work. You can buy just the ribbon cables but
I chose to buy these instead as the ribbon cable is already connected to the LCD's and you get new LCD's. Pretty cheap at only $33.
https://www.ebay.com/itm/394622012375
Old Jun 28, 2023 | 06:49 AM
MBZ 1787's Avatar
W208 320 (05) / 190E (91) / W117 (17) / A208 (03)
Thanks for this but how easy was the installation?
did you manage to do it yourself or did you remove the cluster and sent it to a mechanic?
Old Jun 28, 2023 | 07:28 AM
marko69's Avatar
I did it myself. I would not call it an easy job. I wouldn't have been able to this without a couple of youtube videos. First you have to figure out how to get the instrument panel out. Then you need to completely disassemble the cluster and remove the ribbon cable's with the LCD's. Then attach the new ribbon cables and put it all back together. It was pretty time consuming, but I think it was worth it.
