Scratching metal noise after letting off throttle
Old Sep 5, 2023 | 02:36 PM
Chameleon_CLK's Avatar
Clk 230 kompressor
So i've got a w208 230kompressor and after coming back from a 2 week vacation, i started it and heard a new weird noise coming from under the hood, so i went to see what it was and it's this metal scratching/taping noise coming from the exhaust manifold side of the engine, i thought it might be the exhaust heat shield which had come loose but i checked every bolt and it wasn't the case.So i then started to check all of the engine pulleys, which led to nothing, so i also checked for the SC bypass valve, to see if it was having trouble closing/opening and it seemed to be working fine... I want to believe that it's not a faulty SC/kompressor but if it is, i do have a spare one.I'm kind of lost on what to search for now, if anyone can give it a listen and see if they recognize the sound and pinpoint the problem, it would be much appreciated!
Here's the link for the clip i recorded:
https://youtube.com/shorts/EY8pAH2usBI?si=FF-fyY3dBym8I84s
