CLK 430 Ignition problem
My CLK430 (2002) won't start. I go into the car, put the key in the ignition, hear the steering lock come off, but the key will not turn anymore than that.
Putting the key in allows the radio, lights, seats etc to work, but the windows do not move and are stuck down.
The car has no fault codes and is accepting the key as the correct one. The ignition switch has been taken apart and proved to be working on a bench tester. A mechanic has gone through every fuse and proven them all to be working. The starter motor is working if power is applied directly to it.
If anyone has any idea of what to do or has experienced similar I would love to hear from you! I'm about a thousand pounds out of pocket from this issue and am on the point of crying.
Thanks very much : (
EDIT: The car just rolled off the tow truck after 300 miles and started first time. I am being punished by God.
