Help with Ignition Position Sensor or Crank Sensor
Old Nov 19, 2004 | 03:35 PM
lionj's Avatar
Unhappy Help with Ignition Position Sensor or Crank Sensor
Hi all,
I am having problems with my '99 clk320 not turning over when I try to start it so I did a search and found out this was a common problem, I bought a new Ignition Position sensor and installed it but I'm still experiencing the same problem, can someone please assist me, thanx in advance
Old Nov 19, 2004 | 05:07 PM
QB320's Avatar
sorry to hear about your problem. It could be the fuel pump.
By the way, did you install the sensor yourself? How difficult was it? If you did the install, could you post some instructions?
Thanks.
J
Old Nov 19, 2004 | 11:39 PM
lionj's Avatar
Sorry, but a friend installed it for me when I was at work, but can you explain the fuel pump thing, don't quite know how they connect, thanx in advance.
Old Nov 20, 2004 | 10:04 AM
nickv's Avatar
Used to be a CLK430
The crankshaft position sensor problem is actually when the car will turn over, but will not crank over to start the vehicle. What do you hear when you try to start the car?
Old Nov 20, 2004 | 01:01 PM
lionj's Avatar
Hey nick,
That is exactly my problem, it cranks but just doesn't turn over to start. I bought a new ignition position sensor and it's still doing the same thing, it seems to start perfectly when the car is cold but when the car gets hot that's when I encounter it cranking but not turning over, i'm wondering if I got a faulty sensor from the dealership.
Any assistance you or anyone can provide will greatly be appreciated, gets embarrassing, here I am with a benz that looks good and don't even start and a hyundai guy next to me jumps in and is on his way.
Is there a special way to install the sensor?
Old Nov 21, 2004 | 10:13 AM
nickv's Avatar
Used to be a CLK430
Unfortunately I don't even know what the sensor looks like as I didn't install mine. You are correct, the problem only happens when the car is warm. Sorry man, wish I could be of more help. Try PMing MBTECH208, he might be able to offer more assistance.
Old Nov 21, 2004 | 07:36 PM
lionj's Avatar
Hey nick,
When you changed yours, was that the end to your problem cause if it was, then maybe I need to change that new sensor I got? Thanx in advance.
Old Nov 22, 2004 | 08:48 AM
nickv's Avatar
Used to be a CLK430
Yup that was the end of my problems. Also, have you checked the voltage on your battery? I ended up replacing my battery before the sensor as I had killed it trying to crank the car without success. Good luck man!
Old Dec 12, 2004 | 12:11 AM
face118's Avatar
00' CLK 430
I have the same problem too. I drive me crazy. Where I can get the parts? Price? Is it difficult to DIY?
Teresa
Old Dec 12, 2004 | 12:42 PM
lionj's Avatar
Not to difficult, you can get the part at any MB dealership for around $140.00
check previous message for diy instructions.
Old Dec 12, 2004 | 06:08 PM
smalldog's Avatar
clk
The sensor takes @ 30-40 mins to install if you have the correct tools. I paid $100.00 for mine at the dealer. Make sure you get the correct one for your car. MB used 2 types on the 208 body. The only difference between the 2 is the connector end. Read theses links......
https://mbworld.org/forums/showthrea...ghlight=sensor
Old Dec 13, 2004 | 01:54 PM
face118's Avatar
00' CLK 430
I try to order at mercedesshop.com. They quote me $134, is it right? the part no. they gave me is 004 153 69 28 - 'CAM position Sensor'
