1999 CLK 320 Cabriolet Automatic Transmission question
Old Jul 6, 2024 | 11:18 PM
gss100's Avatar
My car has 104,000 miles but has never had a transmission oil change. It is running perfectly.
Do I get a transmission oil and filter change now? Or leave it alone?
Thanks.
Old Jul 13, 2024 | 06:54 PM
andy_breuer's Avatar
CLK 430
Great question. My 2003 CLK430 has 98,000 miles and I haven’t changed the transmission oil, and don’t plan to very soon. I will probably change it at 120,000 but only drop the pan and fluid and change filter then refill. No flush needed. The engines and transmissions on these cars are pretty bulletproof.
Old Jul 13, 2024 | 09:33 PM
austinramsay's Avatar
1999 CLK430
You should 100% change the fluid. Not only just drain the transmission pan fluid and replace filter, but also drain torque converter fluid as well. I would recommend Liqui Moly Top Tec ATF 1600. You can purchase from several vendors, but I've purchased it from ECS Tuning before. You'll need roughly 8/9 quarts if you drain pan and torque converter. I would also recommend getting a new drain plug bolt and washer for both the pan and torque converter. Also, theoretically the transmission pan bolts are one time use. You can use originals again, but if you're there honestly just replace them. Make sure you torque the drain plugs and transmission pan bolts to spec with a torque wrench. If I remember correctly, it's 8nm torque spec for transmission pan bolts. I can't recall the drain plug torque specs but there should be plenty of info here on the forum for that. If you can't find it, let me know and I can check in WIS.
Should be several youtube videos on how to do transmission service on a 722.6 transmission and torque converter to help you understand the process a little better! On the W208, it's really not hard at all.
Old Dec 3, 2024 | 10:11 AM
İsmozx6's Avatar
Clk200
Benim 1999 model w208 Cabrio aracım var 136 beygir şanzıman yağını değiştirsim fakat şanzımandan gelen yağ kaçağını kesemiyorum civatalarını kaç tork sıkmam gerekiyor
