Engine Check light...
Old Nov 23, 2004 | 09:27 PM
Money's Avatar
Question Engine Check light...
I need to get my smog done for registration. The only thing is my engine check light is on so it wont get passed. Does anyone know how I can reset the light. Maybe disconnecting the battery etc... Thanks for the help.
Old Nov 24, 2004 | 09:43 PM
Money's Avatar
bump
Old Nov 25, 2004 | 12:39 AM
clkal's Avatar
01' CLK55
if you have already tried the smog test and failed.....the print out on the smog certificate will tell you exactly what is wrong.... it prints out the codes for you. There's really no way of passing w/o fixing the problems....most likely it's either the 02 sensors, mass air flow sensor.
oh yeah....stupid question, but have you checked to see if your gas cap is on tightly?
Old Nov 25, 2004 | 06:54 AM
Money's Avatar
I didnt know that was your car. I have your pic set as my background. Thanks for the advice.
Old Nov 25, 2004 | 12:24 PM
clkal's Avatar
01' CLK55
no problem. There are many members on this forum that are far more knowledable than I am, and I'm pretty sure that they would have given you the same advice. Good luck.
