CLK230 -00 No throttle response
Old Aug 22, 2024 | 08:16 AM
jevlar's Avatar
E55 -05
CLK230K -00
M111.973 engine
Car has been parked since last year so I suspect the battery have been flat and a jump start have been done.
Starts and runs poorly on elevated idle, approx 12-1300rpm
It's very rich so I think it's on some kind of failsafe mode.
Dos not respond to throttle pedal at all.
No logged or active codes when checked with HHT-win
Checked pedal sensor and throttle valve position sensor signals and they are correct both in hht-win and when measured with dmm over the full range of movement.
Throttle valve does not move when attempting to increase or decrease position with actutations in hht-win either.
At key on the valve briefly moves to it's fully closed position and then goes back to the "rest" position.
Throttle motor works in both directions when driven by an external power supply off the car.
Anyone seen this before and have the fix?
Old Aug 23, 2024 | 10:43 AM
andy_breuer's Avatar
CLK 430
I have not heard of this specific before. But I would suggest attempting the throttle reset procedure. Turn key to position 2, but don’t start. Press throttle peddle to floor for 10 seconds. Keep pedal pressed and turn key off. Remove foot from throttle and wait 2 minutes. Then restart.
Old Oct 1, 2024 | 06:06 AM
Hydrojim's Avatar
CLK 320 convertible 2005
Originally Posted by jevlar
CLK230K -00
M111.973 engine
Same problem with mine , simple fix I'm the driver side fuse box under the hood a series of connectors the connector block was loose pushed it back in and locked the connector block and it works fine, I think it controls the injectors I was about to get a tune up idle was ruff and after locking the connector block made it run great
...the only thing I think it's the windshield guy who forgot to lock it ,,,,no names of company but it's the front block check that out...... Good luck your clk .. I love mine
Old Oct 2, 2024 | 04:24 PM
DeLasse's Avatar
2001 CLK 320
so to clarify, you're running old/bad gas through it and it's not running well?
