A-Pillar Exterior Panel
Old Sep 25, 2024 | 04:58 PM
Chazz3323's Avatar
2004 ML 350
Hello! I've searched the web and I've not been able to find this, so far. I figure someone on here will likely know. The plastic body panel/cover on my driver's side A-pillar has popped off on the top. No idea how, but I definitely want to re-secure it before I lose the whole thing. I am including two pictures, the first is the A-pillar that this is attaching to - you can see the two posts. The second picture is the panel itself and I have circled what I am assuming the issue is. There appears to be only one of the plastic 'grommits' (for lack of knowing what this is called) and I am missing the other. I'm not sure if the existing one is stripped or broken or what, since it doesn't appear to be latching onto the post, at all. So what are these called and where do I get them? Are these my only problem (so if I get two new ones, should this work) or is there something else I am missing? Thanks in advance for the guidance.
Old Sep 27, 2024 | 10:51 AM
DeLasse's Avatar
2001 CLK 320
can you show another picture from further back? i'm a little unsure what panel that is
is that orion blue?
best
Old Sep 27, 2024 | 11:34 AM
Chazz3323's Avatar
2004 ML 350
is that orion blue?
best
Quartzite Blue Metallic
Old Sep 27, 2024 | 12:12 PM
DeLasse's Avatar
2001 CLK 320
it appears these are bolts are driven through the exterior of the car from inside -- during manufacturering, and then welded -- if I am looking at this correctly.
I can't find this part on partsgeek, but these may be the common insert that is undernearth the car as well. I'll take a picture of these when I'm at my car later
Old Sep 27, 2024 | 05:24 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Try this...use info on mbparts.com to find...Hope this help
https://www.ebay.com/itm/19604182062...SABEgIfPfD_BwE
