Driver's seat issue
Old Nov 25, 2024 | 01:03 PM
fischpj's Avatar
1981 380SL, 2003 clk430, 2009 s550
Driver's seat issue
The drivers seat on my 2003 CLK430 does not move forward or backward via the seat adjustment/positioning switch on the door, it does move perfectly using the memory buttons (fortunately the PO had programmed them), aka the motor isn't jammed and the computer seems to be responsive. I do hear a click once in a while when trying to slide the seat forward and backward using the door switches/seat buttons, but no motion at all. Moments after trying the switches I try using the memory buttons and it moves correctly. I've also tried throwing money at the problem by buying a used set of seat switches and there's no change in the symptoms.
The seat never fails to move correctly using the memory buttons.
Any thoughts or suggestions?
Old Nov 27, 2024 | 10:49 AM
fischpj's Avatar
I managed to fix the issue... After reading more posts I saw that the most common way to remedy seat positioning weirdness is to adjust the seat without sitting in it. I stood outside the car and managed to get the forward/backward seat motor to go through its motions. When I hit the forward and backward limits of the seat I kept pressing the directional switch for another 10 seconds, once for each direction, and it seems to have worked.
