Timing Chain / Guide Questions
Old Dec 5, 2024 | 07:40 PM
etownbala1's Avatar
So I cracked the lower right timing chain guide while removing the timing cover. I was an idiot and forgot to take out the timing chain tensioner bolt and it caused the crack. Now I need to replace it.
Questions:
1. Do I need to remove the valve covers to replace the guides?
2. I assume I need to cut the chain to replace the guides at a minimum. If the chain is in good condition, which it appears to be, should I just buy a pin for it? Or play it safe and replace the chain? Car is a 2001 CLK 430 with about 140,000 miles on it.
3. Is there anyway to replace the guide without removing the chain? Any creative ideas. Just trying to save some cash here.
The guide rail in question is the one in the picture below on the lower left hand side of the "V" assembly.
3. Is there a way to replace the guide without removing the chain?
Old Dec 16, 2024 | 06:19 PM
etownbala1's Avatar
Hey guys just bumping this up to see if anyone has any info on the timing chain or guide rails?
Old Jan 13, 2025 | 07:06 PM
etownbala1's Avatar
Buuummmpppppp. Anyone have timing chain guide replacement experience?
