Disconnecting fuel rail fitting
Old Mar 15, 2025 | 05:41 PM
jinark's Avatar
Veteran: Navy
2003 CLK 320 convertible
Hi. A quick question. Car is a W208 Cabriolet 3.2. I'm replacing the rocker arm cover on the left, driver's, side of the engine. Toward the rear of the ending there is a steel line with a braided hose over it that I believe is the fuel line that attaches to the fuel rail. Are there any dire consequences to removing that line to make it easier to reinstall the rocker arm cover? There are two fittings, one at the fuel rail and one further from the engine. I assume I can loosen both to remove that section of line and then reinstall it. Will I face any issues other than a brief spurt of fuel under pressure? and is there any kind of bleeding involved after reinstalling the line? Any special sealants involved?
Thanks,
John
Old Mar 15, 2025 | 05:54 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Nope. Rip 'er out. Careful with the fittings. Might want to use a six sided hose wrench if you have it.
smart move is to replace the O-rings that are inside of it when you put it back on they're very inexpensive.
Old Mar 15, 2025 | 07:12 PM
jinark's Avatar
Veteran: Navy
Great, that was quick. I do have flare nut wrenchs. Thanks.
