Transsmission Woes
Old Jun 22, 2025 | 08:45 PM
jinark's Avatar
Veteran: Navy
2003 CLK 320 convertible
Transsmission Woes
2003 CLK 320 Cabriolet.
We were on a trip about 70 miles from home when I step out to pass a car on a two lane road and the transmission fails to downshift when I mash the go pedal. Turns out the transmission won't shift out of top gear. Come to a standstill and it stays in top gear. We got home by shifting the transmission manually. That works fine.
Does anybody have a list of possible causes and diagnostic steps I can take with normal garage hand tools. To the best of my knowledge the transmission has never been touched, I know I haven't done anything to it in the 11 years and 70K miles we've owned it.
Old Jun 23, 2025 | 01:19 PM
jinark's Avatar
Veteran: Navy
A followup.
Maybe fixed, maybe not. I found a process on You Tube to reset the transmission. Did that, started the car and went for a brief drive and all seems well.
Time will tell.
Old Jun 24, 2025 | 04:20 PM
jsakabuck's Avatar
Mercedes Benz S 580 e
I think you nailed the problem and the fix for it. Similarly, my '99 CLK Cab wouldn't shift out of first gear (neither automatically nor manually). A reflash/reset of the transmission cured that ill. That was five (5) years ago, not a problem with the transmission since.
GULP!
I hope I didn't just jinx myself.
Old Jun 24, 2025 | 06:50 PM
jinark's Avatar
Veteran: Navy
Thanks, Hope so. God only knows what the cost is to overhaul a Mercedes transmission.
Old Jun 24, 2025 | 09:02 PM
ML Dude's Avatar
If you’re keeping her you may want to invest in a decent scanner, I use Autel. The need to know stored codes and clear to replicate
the issue is invaluable in troubleshooting. Hope you solved it for now!
