Disconnected battery and problems when reconnected
So... after about 30 minutes I reconnected the battery. Now when I start the car I see a BAS, Brake Assist System error and the fog lights are on all by themselves and never go out. Please note that the car never moved and never had these issues prior to the reset. I did try resetting it again, (what could happen?) and got the same results/issues. I then walked away calmly and went overseas for three weeks for work. Upon my return, I reconnected the battery and nothing has changed and the car is still in the same sorry state.
So, my CLK is sitting in my driveway with no battery connection, so the fog lights don't kill the battery. Does anyone have a suggestion please?
Thanks!
Also, I have the battery drain issue, I currently have disconnected the fuse for the SOS system and that has kept the battery from draining for over a year. I think the fuse is #4. I have heard that this can also be fixed by going to the Mercedes Dealer to have them turn off the SOS system which is using its internal cell phone to try to call-in constantly.
I'm still stuck on the fog light issue though.
From what I've "Googled" it sounds like my front SAM is "confused" by the power outage. I've tried disconnecting the battery several times with more and more lights staying on now. My two fog lamps and parking lights all around the car are on now as soon as I connect the battery. This does kinda sound like a software panic of sorts on the SAM's part. I don't know of anyway to reset the SAM without driving to a service shop with a STAR or similar tool to do a reset. Sadly, my Topdon 900Lite doesn't talk to this car... Does anyone have any ideas?
