2001 CLK430 85k miles $2500
Hey all,
Found a 2nd owner family owned 2001 Mercedes CLK 430 Coupe (non convertible). It has 85k miles on it. Seller claims good condition and maintenance. Says there are a couple cosmetic issues like paint chips here and there and a button that needs to be reattached. He’s selling it for $2500. No accidents. No check engine light. Clean title. I drove it today and it drives great, I might get wheel alignment soon if I buy it. What should I expect experience and maintenance wise? Carfax indicates average annual mileage of around 4k miles. Any advice will be appreciated. First time buying a car and just want something fun and sporty that runs me the next 3-4 years.
carfax history-
The following list details the documented service and replacement history for the 2001 CLK430:
Engine & Performance: Crankshaft position sensor replaced ; mass air flow sensor replaced ; valve cover gaskets replaced ; air filter replaced ; engine/powertrain computer/module reprogrammed ; blower motor resistor replaced ; and recent oil and filter changes.
carfax history-
- Maintenance & Fluids: Antifreeze/coolant flushed and changed ; brake fluid flushed and changed ; and regular maintenance inspections completed.
- Brakes & Suspension: Front brake pads and rotors replaced ; steering damper replaced ; lower ball joints replaced ; steering knuckles replaced ; and brake light switch replaced.
- Electrical & Body: Battery/charging system checked and battery replaced ; right front window regulator replaced ; door trim panel repaired ; wipers replaced ; tail light assembly and bulbs replaced ; license plate light bulb replaced ; and instrument cluster checked.
Wheels & Tires: Multiple tires replaced, mounted, balanced, and repaired ; tire condition and pressure checked ; and four-wheel alignment performed
Mercedes CLK W208 All Models
Read the articles on this site, rag14. You will get a good idea of what you are letting yourself in for.
Some parts and trim, are very hard to find (UK) and other countries.You will spend a lot of time on
e.bay and scrap yard sites, looking for parts.Be prepared to shell out eye watering money, for second
hand parts.No longer available from Mercedes. I have got a 2001 W208 CLK 200 Cabriolet.Good luck..
'99 CLK/05 E500 WAG
Get it! $2500.00 is a steal with 85k on the dail. Most of the maintenance has been completed, and only needs minor fixes..Do you have any pics of car/interior?
R,
2Merks
R,
2Merks
